parrish | -- 10-10-2010 @ 9:19 AM |
anybody know who makes subrails? thanks.
ford38v8 | -- 10-10-2010 @ 12:56 PM |
Parrish, I would try Speedway. http://www.speedwaymotors.com/ Alan
trjford8 | -- 10-10-2010 @ 8:07 PM |
You might try EMS( www.emsautomotive.com) or Precision Coachworks ph# 978-663-7573.
40 Coupe | -- 10-11-2010 @ 5:39 AM |
Dennis Carpenter used to have them but are no longer available. EMS does not make them with the details as the originals such as the oval bump outs for the trim and the V notches. Precision Coachworks makes them for the station wagons. McPherson has them with the oval bump outs but not the V notches, they do return to the frame on the bottom $$$$$. check with the above suppliers and any others to see if anything has changed. If you find a source let us know!
parrish | -- 10-11-2010 @ 8:16 PM |
I ordered them from Steve Kinzel at Mcpherson. Good guy. How about body mounts (or stand offs). Precision has them at $95 each which seems high...
40 Coupe | -- 10-13-2010 @ 4:59 AM |
I have used Precision Coachworks parts and have found they are right on. They appear as if they just came off of a Ford dealers shelf. There is another supplier whos body mounts appear to weld in place and are without the appearance details.
parrish | -- 10-14-2010 @ 8:52 AM |
Other than Precision, who is the other body mount supplier? Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1983 |
