rdove | -- 10-08-2010 @ 3:52 AM |
Where can I send my 1948 H series 6 cylinder water pump to get it rebuilt?
TomO | -- 10-08-2010 @ 8:16 AM |
New water pumps for your 6 cylinder engine are available for less than the cost of rebuilding the pump. You can try Skip in Florida for rebuilding. Skips email address is skip@fordsrus.com day phone 1-941-637-6698. Tom This message was edited by TomO on 10-8-10 @ 8:16 AM
supereal | -- 10-08-2010 @ 9:33 AM |
C&G (800/266-0470) also rebuilds the six cylinder water pumps. They used to charge $150. Their 7HA kit is $55. It is not uncommon for the housing to need some repair or machining, so if you are not prepared to do it, sending out is likely a better choice.
rdove | -- 10-09-2010 @ 5:07 AM |
Thank you Gentlemen. I will check with both of them.
37RAGTOPMAN | -- 10-10-2010 @ 10:31 AM |
KANTERS AUTO PARTS, has new ones,in stock for your 6 cylinder. they have a web site, check them out, hope this helps 37RAGTOPMAN.,an KEEP on FORDIN,,,!!!!
trjford8 | -- 10-10-2010 @ 8:11 PM |
Also try Napa Auto Parts. It's possible that they may have them.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1974 |
