choupie | -- 10-06-2010 @ 4:36 PM |
If you need to replace the dome light bulb in a '34 5-window coupe, how do you remove the lens cover to get at the bulb?
flatheadfan | -- 10-06-2010 @ 5:32 PM |
Easy! Look closely at the dome light and you will see a snap ring circling the glass. Use a small screw driver to lift out the snap ring and the glass will fall out (be ready to catch it!). The bulb is now easily accessible. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1970 |
