zeker8 | -- 10-26-2009 @ 3:53 PM |
To install a 42 distributor on my 39 block, what needs to be done ? Can the timing cover be changed, cam, I see Speedway has a spacer to put a 2 bolt on a 3 bolt timing cover. I'm guessing that the 42 drive tab is longer on the dist as I see a drive adapter to go the other way. I have my engine disassembled and looking for some options. Thanks Zeke
TomO | -- 10-26-2009 @ 4:42 PM |
You can change the camshaft and front cover or buy the spacer from Speedway. IMHO the helmet (37-41) distributors are easier to service than the 42 Crab style. Tom
ford38v8 | -- 10-26-2009 @ 4:50 PM |
Zeke, yes, the timing cover and the spacer. Alan Alan
supereal | -- 10-27-2009 @ 8:58 AM |
The "crab" distributor was a one year only type. It was replaced because it had problems with water infiltration of the cap. I agree that the correct type for your car is a better choice than converting to the crab style.
37 Coupe | -- 10-27-2009 @ 4:39 PM |
Never gave the 42 crab much thought about moisture problems but you are correct 9 places for water to get in besides cap gasket,only two plus two caps to let water in, or coil base gasket on 37-41 helmet type.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=197 |
