Robert/Texas | -- 09-30-2010 @ 4:25 AM |
My’34 has a near stock ’36 engine with a Mallory (centrifugal advance only) distributor. This distributor has three elongated mounting holes. Standing in front of the car, which direction should the distributor be turned to advance it?
Stroker | -- 09-30-2010 @ 6:18 AM |
As it is driven off the timing gear, which turns opposite to crank rotation, turn the distributor in the same direction as the crank turns,(clockwise) to advance the base timing.
Robert/Texas | -- 09-30-2010 @ 7:01 AM |
Thanks Stroker, that's what I remembered (from the early 50's). Just wanted conformation, working on even easy stuff is getting harder as I age.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1936 |
