sunflower | -- 09-29-2010 @ 5:01 AM |
How do I know the RPM on my 35Ford is there a company that makes hand held ones that are not to expensive,and what RPM shoul my car idle at? Thanks
40 Coupe | -- 09-29-2010 @ 5:22 AM |
knowing the rpm is not necessary. Take the idle down to a pleasant smooth purr, without any lope. The idle rpm is not a critical setting.
supereal | -- 09-29-2010 @ 9:36 AM |
A vacuum gauge is a good tool to set idle speed. After obtaining the desired rpm, usually around 500-600, adjust the idle needles for maximum stable reading.
sturgis 39 | -- 10-01-2010 @ 3:21 AM |
When flying radio controlled air planes I had a hand held tach. You just held it in front of the prop.This was 30 years ago.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1933 |
