Keystone 34 3w | -- 09-20-2010 @ 9:07 PM |
This is not a serious problem but I can`t seem to keep the w/s frame from getting pushed in by the wind at speeds over 40mph. It stops against the vacuum wiper pipe will driving and I have to push out the frame every time I stop. I tried tightening the wing nuts tighter but don`t want to damage the threads. Is there suppose to be something between the cones and the w/s posts to help this or is it normal for the w/s to always get pushed back by the wind?
37RAGTOPMAN | -- 09-21-2010 @ 6:03 AM |
Did you try using fiber washers or small 'O' rings? maybe from some carb overhaul kits,also hardware plumbing washer kits. its worth a try, I had the same problem with a MODEL A SEDAN with the windshield kept on closing, and added a fiber washers and problem solved. metal washers will or seem to slip. hope this helps,37RAGTOPMAN an KEEP on FORDIN...!!! Also NICE FORD'S in the pictures. This message was edited by 37RAGTOPMAN on 9-21-10 @ 6:05 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1894 |
