toms32 | -- 09-14-2010 @ 6:37 PM |
I have a 32 Ford Frame but I am mising the running gear. I have an opportunity to purchase a 1933-34 front and rear axle assy. Are these basically the same as the 32 width and length and will they innerchange on my 32 chassis. Thanks for any help on this. Tom
40 Coupe | -- 09-15-2010 @ 3:41 PM |
suggest you email Jim at deucemeister@roadrunner.com he can probably help you.
Stroker | -- 09-15-2010 @ 4:03 PM |
I believe that the 32 rear spring is special, in that when viewed from above, it curves forward towards the outside ends. The 32 rear spring mount on the frame is behind the axle banjo housing, but the ends of the spring mount to the top of the axle ends. I'm not positive, but I think this is unique to the 32. I do know that the rear cross member on a 32 frame is curved to accommodate the curved (as viewed from above), 32 rear spring.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1856 |
