sonof19 | -- 09-14-2010 @ 11:40 AM |
mabe some one can tell me how many amps a 1948 ford V8 heater will pull with a 12v system? am needing to get a voltage drop resister.Is it 4 or less. thanks again for your help.
supereal | -- 09-14-2010 @ 12:20 PM |
Motors typically draw considerable current, particularly when first started, so a heavy duty reducer is required. You can find a 12 amp 12 to 6 volt reducer on page 232 of the C&G catalog as item number B-10606, about $30. 800/266-0470
sonof19 | -- 09-15-2010 @ 10:53 AM |
Thanks supereal that help a lot I will call today. sonof19
sonof19 | -- 09-15-2010 @ 11:50 AM |
Hey supereal" I check with CG that part is no longer available. I was hope you or someone has a another source for a 12 amp 12v reducer. thanks son of 19
sonof19 | -- 09-15-2010 @ 11:51 AM |
TomO | -- 09-16-2010 @ 8:58 AM |
Google it. There are many of them on the market. Speedway Motors has a couple of different reducers. Tom
sonof19 | -- 09-16-2010 @ 3:12 PM |
Thanks Tom"
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1853 |
