rstefani59 | -- 09-07-2010 @ 8:48 PM |
Does anyone know where to get a new oil pressure sending unit for a stock 36? I believe it is a 50lb one. Thanks
37RAGTOPMAN | -- 09-08-2010 @ 4:56 AM |
if you want a new one, that will work try JOBLOT AUTOMOTIVE 800-221-0172 , its not a genuine FORD, but will work,and is 6 volts also reguest a catalog, hope this helps, 37RAGTOPMAN an KEEP on TRUCKIN,,!!!
parrish | -- 09-10-2010 @ 9:11 AM |
joblot is a great supplier and I've used them since 1970 when Ray ran the place. they have an 80lb unit and high volume units as well as rebuild kits
37RAGTOPMAN | -- 09-10-2010 @ 1:09 PM |
There is a 50# oil pressure switch, in the classified secton, on this web site, check it out, hope this helps 37 RAGTOPMAN an KEEP on FORDIN...!!!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1825 |
