carcrazy | -- 08-26-2010 @ 3:12 PM |
What is the best clutch pressure plate to use on a Ford V8-60 Engine with flat flywheel when mounting it to a Chevy S-10 5-Speed Manual Transmission? The diaphragm pressure plate that came in the S-10 2.5L 4-cylinder Clutch Kit has mounting holes on too large a bolt circle to fit within the flywheel ring gear. Is there a smaller diameter diaphragm type pressure plate that is compatible with: the Chevy 9 1/8" Clutch Disc with 14-spline hub, Chevy Release Bearing, and fit within the Ford Bell Housing and Ford/Chevy Adapter?
37RAGTOPMAN | -- 08-26-2010 @ 5:35 PM |
What about the original 60 pressure plate and the Chevy clutch disc ? seems to me the pressure plate will bolt right up with no modifcations,right to the original 60 flywheel just my 3 cents worth, 37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1770 |
