Furtex | -- 08-21-2010 @ 5:01 PM |
I can't figure out how to remove the door window in my '36. When the window is all the way down I can see the rollers in the channel, but I can't see any way to get them out of the channel. Can anyone help?
Furtex | -- 08-21-2010 @ 6:01 PM |
I figured it out! When the window is up, there is a bolt visible in a hole in the door panel. If you remove that bolt, it allows you to roll the window down far enough that the rollers come out of the channels.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1743 |
