Captainrchill | -- 11-01-2024 @ 12:43 PM |
Does the pushrod tube for the pushrod that that drives the fuel pump arm, via the camshaft, have to be used? Not sure the reason they are actually there. I do not have one, other engines show it installed on the breather/oil filler casting that is also the fuel pump bracket.. Robert Hill New Member
40 Coupe | -- 11-02-2024 @ 4:57 AM |
It should be there for oil control in that area. The tubes come in two, 1" different lengths, make sure you get the proper length. Have a photo of the intake manifold and the oil filler tube? This message was edited by 40 Coupe on 11-2-24 @ 4:59 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17290 |
