chucky | -- 10-29-2024 @ 12:32 PM |
can anyone tell me where the rear driveshaft bearing goes on a 36 ford and what it looks like. Also where I can find one. Thanks...
ford38v8 | -- 10-29-2024 @ 1:09 PM |
A ‘36 Ford has a hollow driveshaft, without a bearing. The later solid driveshafts have a rubber mounted bearing at the center of the torque tube, having a zerk fitting for lubrication. Alan
chucky | -- 10-29-2024 @ 2:27 PM |
Thank you Alan. I thought there was a bearing in the middle. What about the end near the differencial?
ford38v8 | -- 10-29-2024 @ 11:08 PM |
Nope. The pinion bearings perform that task for you. Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17286 |
