Robert37 | -- 10-24-2024 @ 4:00 AM |
Rebuilding a 1937 Ford Phaeton and looking for parts and also looking for a company that deals with interior upholstery. 1. Trunk lid hinges R.H & L.H. also the cup washers 2. Steel adjustable rail supports for front cushion seat 3.Steel support brackets for back cushion seats 4.Back cushion springs + back rest spring 5. Open car top front header wood bow
37RAGTOPMAN | -- 10-24-2024 @ 8:04 AM |
hi seat spring, SNYDERS has some sets spring listed for the FRONT SEAT and has back seat spring for 1936 PHAETON, if this helps 37Ragtopman, Maine maybe the 36 rear seat spring can be used with a little work to them there can not be a lot of difference, I would get a 36 and a 37 parts book and do a part list number, compare,them
trjford8 | -- 10-24-2024 @ 9:16 AM |
ragtopman makes a good suggestion about getting a 37 parts book. Some of the parts you are looking for may fit other 37 body styles. The parts book will tell you by the part number. You can get the book from various V-8 parts vendors.
v8er | -- 10-24-2024 @ 9:54 AM |
Oak Bows in Chambersburg, PA has the header bow.
BRL | -- 10-27-2024 @ 11:02 AM |
Hi Robert37: The trunk hinges for the 37 Phaeton (78-750) were common to the convertible sedan (78-740). They were common to the 38 Phaeton and 38 convertible sedan. They were not common to any other 37 models or other year cars. The part numbers are as follows: 78-748150, right hand hinge on lid 78-748151, left hand hinge on lid If you cannot find these parts anywhere, but you do have old broken parts, a solution would be to have the parts scanned and then 3-D printed. You would also then have to have them tapped, polished, and chrome plated. The pin attaching the two halves of the hinges is probably common to all other trunk hinges and can be found. A company that can scan and 3-D print the parts is HV3DWorks. The cup washer, 78-706865, was common to many models in 37 and 38, and hence I would expect you can find some.
v8fordman | -- 10-31-2024 @ 5:42 PM |
I have hinges and cup washers as well as many other '37 parts. If you don't find a header, I may still have a pattern if you can find someone to make it. Contact me at v8fordman@hotmail.com. I have both a phaeton and convertible sedan. This message was edited by v8fordman on 11-3-24 @ 5:20 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17278 |
