Rybcon | -- 08-17-2010 @ 1:38 PM |
Trying to find the original bolt specification for the bolt that attaches the inner front fender panel to the front fender bracket. Maybe the picture will help the experts. Thanks
supereal | -- 08-17-2010 @ 2:09 PM |
The "green book" isn't specific regarding the bracket bolts (see pg. 599). There are three sizes used in that area: 1/4", 5/16", and 3/8". The threads are 24 pitch for most, with length to accommodate the position. Thus, you can determine the size of the hole and the length required to hold the parts together and leave room for the nut and a common lock washer. The 24 pitch was often used by Ford, but would be concealed in position, in any case.
Rybcon | -- 08-17-2010 @ 4:19 PM |
Thanks, as always, for the quick response.
TomO | -- 08-18-2010 @ 7:37 AM |
Here is the list of front fender bolts in the 36 parts catalog. Excuse the poor reproduction, but I just scanned them. 20337-S2 FRONT FENDER BOLTS 5/16"-24 x 11/16" hex. head bolt 20357-S2 5/16"-24 x 13/16" hex. head bolt 20369-S2 3/8"-24 x 7/8' hex. head bolt 20387-S2 5/16"-24 x 1" hex. head bolt 20407-S2 5/16"-24 x 11/8' hex. head bolt 20427-S2 5/16"-24 x 11/4' hex. head bolt 23356-S2 1/4 _20 x 9/16" round head carriage bolt 350240-S2 No. 12-24 x 9/16" binding head screw 350311-S2 1/4"-20 x 1/2" binding head screw 350432-S7 5/16"-24 x 1" hex. tapered bolt Tom
nelsb01 | -- 08-18-2010 @ 3:32 PM |
Suggest you contact Roy Nacewicz. He has done his homework on this stuff and sells kits with just what you need to re-assemble your Ford. You can find his link from this webpage.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1720 |
