sarahcecelia | -- 07-21-2024 @ 11:54 AM |
My memory is letting me down;I'm 87 now, and will be 88 in march 2025. I used to know how to check the governor to see if it was good. My memory says; take it off the transmission, hook the shaft on it to my electric drill,rev the drill up,and if it's good I will hear a click when it engages. What did I leave out or state ,wrong?? Regards, Steve Lee
carcrazy | -- 07-21-2024 @ 7:14 PM |
That sounds about right. Once the governor senses a road speed of about 28 MPH the points in the governor will close allowing current to flow to the overdrive relay.
sarahcecelia | -- 07-22-2024 @ 4:17 AM |
OOPS! I found my directions to test an overdrive governor!! Regards, Steve Lee
sarahcecelia | -- 07-22-2024 @ 4:22 AM |
One has to take it off of the transmission,; hook it up to the cars battery with a test light; the light will be on;(points are closed)Spin it with a drill, light goes out ; if the unit is good. (points have opened) Regards, Steve Lee This message was edited by sarahcecelia on 7-22-24 @ 4:35 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17143 |
