flatfoot | -- 07-19-2024 @ 5:28 PM |
How do you install the glove box door springs ("C") shape install on a '36 Ford 4dr sedan? I see how they go in the door itself but not where they attach on the opening,(???????) Thanks a lot fellas.
TomO | -- 07-20-2024 @ 9:05 AM |
For a photo of the spring installed see this topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=15183&keywords=glove%20box Doesn't the 35-36 book have a photo of the springs? Tom
40 Coupe | -- 07-21-2024 @ 5:07 AM |
With the door upolstery prepared for the spring to fit I install the spring over the dash side lip first , moving the spring down out of position, then slip the spring into the door and down to latch the spring into the door. Finally raise the dash side of the spring into it's final position. This message was edited by 40 Coupe on 7-21-24 @ 5:12 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17142 |
