silverchief | -- 07-12-2024 @ 12:16 PM |
Looking for recommendation for battery cut off switch which is not the type that clamps onto a battery post. 1946 coupe. 6 volt system. Article in auto magazine regarding instrument gauges advised amp gauge in my era Fords remains "iive" even with ignition off, thus makes for a real fire hazard.
carcrazy | -- 07-12-2024 @ 12:52 PM |
Speedway Motors offers this switch which should work for your installation. https://www.speedwaymotors.com/Two-Post-Battery-Master-Disconnect-Isolation-Safety-Kill-Switch,2380.html
GK1918 | -- 07-14-2024 @ 11:48 AM |
Don't know where they got that idea from? The only switched by ign is temp fuel & oil gauge's. The amp meter as well as headlight switch is constant power all the time. All Ford product amp gauge is inductive no terminals it senses current a discharge or generator charge. If you are afraid of fires I suggest replacing wires eaten by rats, thats no joke. If you really want a Kill switch don't forget you need big fat cables to interupt the ground which is positive to the block.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17135 |
