chucky | -- 06-27-2024 @ 8:57 AM |
Does a 36 ford have running/parking lights? If not then my brake lights are stuck on. The switch seems to be ok. Thanks...
carcrazy | -- 06-27-2024 @ 9:03 AM |
The 1936 Ford passenger car does not have running lights.
chucky | -- 06-27-2024 @ 12:54 PM |
Thanks for the reply Carcrazy. Any thoughts on why the brake lights stay on?
nelsb01 | -- 06-27-2024 @ 4:53 PM |
Have you checked the fuse under the dash? Years ago I had the same problem with a 1937 Ford, and replaced the burned out fuse and that fixed the problem. May not solve your problem, but a place to start.
kubes40 | -- 06-27-2024 @ 5:29 PM |
Chucky, Mechanical brakes or has it been converted to hydraulic? Mike "Kube" Kubarth
chucky | -- 06-28-2024 @ 3:58 AM |
The fuse is ok. Onny way to turn off lights is to remove the fuse
chucky | -- 06-28-2024 @ 3:59 AM |
Mechanical
40 Coupe | -- 06-28-2024 @ 4:36 AM |
Is the hand brake on? Sometimes the brake rods rub against each other causing the tail lights to go on even with the car turned off. Operate the hand brake lever several times to see if the lights go on and off.
ford38v8 | -- 06-28-2024 @ 7:32 AM |
Pull the driver side floorboard, under which you’ll find the mechanical brake switch, which is activated by the movement of the brake pedal. The switch itself may be rusted in the depressed position, or may simply be out of adjustment. Alan
MG | -- 06-28-2024 @ 8:10 AM |
Your brake pedal return spring is broken...
chucky | -- 06-29-2024 @ 1:08 PM |
Thanks guys,I will check all those things
flatfoot | -- 08-08-2024 @ 10:13 AM |
Maybe you need a brake light switch that is mounted to the frame and the brake pedal activates when you apply the brakes.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17112 |
