MICHV8 | -- 06-25-2024 @ 4:44 PM |
The original Mainshaft bearing (7065) and the Main Drive Gear bearing 70250 seem to be in very good condition. Is it wise to replace them anyway. I don't have much trust in the new manufacturing stuff. Is Timken reliable? Thanks
lawrie | -- 06-25-2024 @ 4:55 PM |
Sure is, while you have it apart, there are excellent quality available as long as you use a well known brand.SKF, KOYO ,NTN or the like. Lawrie
nelsb01 | -- 06-25-2024 @ 7:18 PM |
Timken is no longer just USA made so you might want to check before putting your money down.
carcrazy | -- 06-25-2024 @ 8:04 PM |
Check with Van Pelt for all of the parts you need to rebuild your transmission. http://www.vanpeltsales.com/FH_web/trans-partsprices-pg1.htm
Drbrown | -- 07-10-2024 @ 9:07 AM |
Regarding Timken Bearings: The company is now in Canada. Some time back I bought a wheel bearing from Rock Auto. When receiving the bearing I saw Timken's name stamped on it. I then discovered Timken's direct web sales site. No surprise, RockAuto had jacked up Timken's price almost 100%.. RockAuto had no sympathy for me. Buyer beware. This message was edited by Drbrown on 7-10-24 @ 9:08 AM
marvella | -- 07-24-2024 @ 1:09 AM |
Bearings can have hidden wear or damage that's not immediately visible. The cost of replacing bearings is relatively low compared to the labor involved in reopening the transmission if a bearing fails later. However, your concern about the quality of new manufactured parts is valid. The reliability of replacement parts can vary. Timken is considered a reputable brand for bearings. They are known for producing high-quality Precision spindle bearings and are widely used in the automotive industry. TBSBearings will be another choice if you want cheap bearings. This message was edited by marvella on 7-25-24 @ 6:53 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17109 |
