1941 Ford Pickup | -- 06-22-2024 @ 8:50 AM |
Other than non-ethanol gas, should I use a lead additive in my fuel? Mike
MG | -- 06-22-2024 @ 9:21 AM |
Not necessary...
juergen | -- 06-23-2024 @ 8:28 AM |
Rebuilder suggested for break in of all new engines
carcrazy | -- 06-23-2024 @ 9:59 AM |
As long as your Flathead engine has hardened valve seat inserts, you do not need to add any lead additives to your fuel. The engine should run well on regular unleaded pump gas with 10% or less ethanol. If it has the stock compression ratio, 87 Octane fuel should be sufficient.
kubes40 | -- 06-23-2024 @ 12:20 PM |
I agree with Carcrazy 100%. I have many of these cars and all run quite well with the ethanol based fuels. Mike "Kube" Kubarth
ford38v8 | -- 06-23-2024 @ 12:45 PM |
Hardened valve seats were in all flatheads except during the Korean war era. They were installed in rebuilt flatheads, which accounts for 99.9% of all flatheads. No lead additive needed unless you have a lumpy cam. Alan
GK1918 | -- 07-27-2024 @ 4:27 AM |
what about flathead lawnmower in the leaded gas days that had to have white gas (unleaded) and they ran for years at full throttle ?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17101 |
