thirtysixford | -- 06-20-2024 @ 8:04 AM |
On a 59AB with the water pumps installed, can the timing cover be removed without dropping the pan? Has original 2 piece rope seals. If I decide to go with a one piece front seat, how is it held in place by the timing cover/ oil pan? Seems like the grove where the rope is is much wider than the one piece seal.
kubes40 | -- 06-20-2024 @ 2:15 PM |
You may remove and install the timing gear cover without the need to remove the pumps nor drop the oil pan. Not certain about the one-piece seal. Never found the need for one. Properly installed, the authentic rope two-piece seals do a magnificent job. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17098 |
