custom | -- 08-15-2010 @ 6:46 AM |
The decal on glovebox door states that type A fluid is the proper fluid for the fordomatic, Is this the same as type F or do they make a specific fl. for this?
buford8 | -- 08-15-2010 @ 8:21 AM |
I have researched this and found Dexron to be the proper fluid for the Fordomatic trans. Dexron is available at most auto supply stores and "big box" stores.
Pat's 52 | -- 08-15-2010 @ 8:30 AM |
Before I had my Fordomatic rebuilt I used type FA that I bought at Carquest Auto Parts. Since I had it rebuilt I use the modern auto trans. fluid. Hope this helps.
Pauls39 | -- 08-16-2010 @ 6:37 PM |
I am having the same problem with a 54 Merc. Is Type F fluid compatible with Type A, or does the whole system need to be drained including the converter? Buford8- Where did you get the info reguarding Dextron as a replacement?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1706 |
