Pvax1950 | -- 05-20-2024 @ 5:19 PM |
It appears something is draining my battery. I take my 34 out for a spin once every couple of weeks, but it is hard to start. Took the battery out and put it on a trickle charger. Took a couple days charging then finally turned green to keep the battery charged. Any ideas what could be draining the battery?
lawrie | -- 05-20-2024 @ 10:31 PM |
Could be like my 33 , brand new optima 6v, started great, then left the battery isolator on AND the interior light for 3 weeks, Battery now toast. Lawrie
Model B | -- 05-23-2024 @ 6:37 AM |
I have had the "cutout" on top of the generator stick and would drain the battery. You might check it. Good luck! Pat
jerry_356 | -- 05-23-2024 @ 6:52 AM |
Had same issue. Turned out to be broken brake pedal spring which caused the brake lights to be on intermediately.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=17050 |
