slasher | -- 04-01-2024 @ 10:51 PM |
i just purchased a33 f ord It is all original. It has been setting for 33 years. What do I need to do before I try starting ? as you can see it cleaned up pretty good.It was stored in dry storage for almost 40 years. This message was edited by slasher on 4-2-24 @ 1:02 PM
40 Coupe | -- 04-02-2024 @ 5:58 AM |
6V, + ground. can you rotate the engine using the fan? How long has the car not run? Is there fuel in the gas tank? A photo of the engine bay would be helpful. Does the car have an electric fuel pump? V8 or 4 Cyl? Beautiful car.
coup | -- 04-02-2024 @ 7:11 AM |
When the hood is up, let it rest on indent, they do get bent.
slasher | -- 04-02-2024 @ 1:00 PM |
The engine turns over and I replaced the gas tank with a new one all the lines are good I replace both water pumps and I will be replacing the fuel pump I plan on taking the plugs out and put a little marvel mystery oil in each cylinder and let it sit for a little bit
CharlieStephens | -- 04-02-2024 @ 1:11 PM |
Please don't rotate the engine using the fan. That is how cracks start leading to fan failure. Do you have a crank? If not borrow of buy one. Charlie Stephens
slasher | -- 04-02-2024 @ 4:00 PM |
Yeah I wouldn’t do that
slasher | -- 04-03-2024 @ 11:17 AM |
I couldn’t find the indent maybe because I’m blind. I have a question the radiator in the 33 is not pressurized I presume?this car hasn’t run in 53 years.I was told that it was 33.
carcrazy | -- 04-03-2024 @ 11:20 AM |
The cooling system in the 1933 Ford is not pressurized.
3w2 | -- 04-03-2024 @ 6:47 PM |
There are no indentations on the cowl lip for the hood side panels to nest into when raised on a '33; that's a '34 addition. It is also fairly clear from the hubcaps and grille ornament that it's a V8. Nice looking Fordor; congratulations! This message was edited by 3w2 on 4-3-24 @ 6:50 PM
dean333 | -- 04-04-2024 @ 10:14 AM |
Wow that’s a beauty! Lucky you. I would send the carb and fuel pump to Charlie Schwendler to be cleaned and updated to gaskets favorable to today’s gas. That’s something I do automatically for any new Ford I get, running or not. TIM CARLIG This message was edited by dean333 on 4-4-24 @ 10:16 AM
slasher | -- 04-04-2024 @ 11:10 PM |
Thanks everyone for the info. I am an 82 year old hot order.I want to keep this one as original as possible and I need help so thank you
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16975 |
