pauloma | -- 03-18-2024 @ 11:33 AM |
Anyone have an idea where I might find an electric wiper kit that will fit my '36 Ford Sedan? I would like one for each side. The car is an original 6 volt positive ground. Thank you to all.
37RAGTOPMAN | -- 03-18-2024 @ 4:09 PM |
HI you might want to see if you can use a JEEP electric wiper motors, like a CJ 5 they are seperate and mounted above the windshield, KAISER FRAZER JEEP PARTS, they are down south, NC, I think hope this helps,37 Ragtopman I would repair the originals or have them repaired, so the car stays original, they might only need a lube if the are stuck, give it a try, nothing to loose
carcrazy | -- 03-18-2024 @ 10:11 PM |
C&G lists a 6V universal electric wiper motor that will fit your 1936 Ford Sedan with some modifications under part no. A-17508-E6. The part is currently out of stock but you can contact them to see when they will become available.
51504bat | -- 03-22-2024 @ 6:23 AM |
Joe's lists a 6 volt unit for a '36 and it supposedly is in stock. https://www.joesantiqueauto.com/electric-wiper-motor-b-17508-mt-6 ______________ No signature
trjford8 | -- 03-22-2024 @ 8:23 AM |
Check with a company called Mighty Wiper. I believe they are in Port Townsend , Washington. they sell a variety of wipers for old Fords.
1934 Ford | -- 03-22-2024 @ 12:44 PM |
At that price, I keep my vacuum wipers and let up on the gas when I want them to wipe. I also avoid driving in in the rain. 1934 Ford's since 1972
51504bat | -- 03-22-2024 @ 2:58 PM |
I believe the unit the Joe's sells is a Mighty Wiper unit but I'm not positive. ______________ No signature
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16956 |
