DDBland | -- 03-13-2024 @ 5:53 PM |
I have trouble connecting the air filter to the carb. Does the end of the filter go over the raised ridge on the carb? Should there be a gasket present? THANKS!
pauls39coupe | -- 03-15-2024 @ 8:45 AM |
Yes the neck of the filter should fit over the flange on the top of the carb. The correct filter should have a matching flange. Some carbs had a straight neck, these were designed for the standard air filter. The oil bath filters had a bulge at the base which matched the flange on the carb. The straight necked filter will not fit on the carb with a flanged top.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16946 |
