Robert/Texas | -- 03-02-2024 @ 10:38 AM |
About a year and a half ago I filled the tank in my original, unrestored 1937 Ford Fordor Touring Sedan with Sh*ll Regular. I’m 89 years old and came down with some medical issues shortly after that so I wasn’t able to drive the car until now. Yesterday I got the car started. It ran rough for awhile but it smoothed out after about ten minutes. I took a ride in it for about 40 miles and it ran great. This morning we went for another ride and the engine started missing after about 5 miles and then stalled. I believe it has water in the gas tank and/or fuel system. Solution: I want like to get all of the water out of the entire system. Any suggestions for the best/easiest way to accomplish this will be much appreciated. Thanks in advance, Robert.
fordv8j | -- 03-02-2024 @ 2:33 PM |
T AKE plug out of bottom of tank and drain it
41fatty | -- 03-02-2024 @ 2:34 PM |
after a year and a 1/2 your fuel should be drained
nelsb01 | -- 03-02-2024 @ 3:57 PM |
Try and find some HEET..............add that to the tank, should help resolve the water issue. If that is what it is.
JayChicago | -- 03-02-2024 @ 9:30 PM |
What makes you think the problem is water in the gas? How was it able to run great for 40 miles the day before?
Robert/Texas | -- 03-03-2024 @ 6:23 AM |
Many thanks for your helpful responses. I found my 1937 Ford book and it shows on page 5-8 where the drain outlets are located on the carburetor and fuel pump. I plan to drain both as soon as I’m able. I’m nervous about removing the fuel tank drain plug and plan to try the Heet suggestion. The reason that I think that my problem is water in the fuel system is that the car is stored in a barn in a rural area along with several other pre-war Fords about 95 miles from my home. There is a lot of summer humidity there and I’ve had a lot of water-in-fuel problems with my A’s and T’s. The ’37 felt like those do when they stall. I should add that I am now using e-free gas in the A’s and T’s and that has solved that problem.
JayChicago | -- 03-03-2024 @ 11:00 AM |
But this came on suddenly. Ran great for 40 miles the day before. Water in the tank would settle to the bottom, get picked up first, would have shown itself in the long drive the day before. Weak/intermittent spark can imitate running out of gas. Common problem with the V8's is the coil and/or the condenser. Both can start failing suddenly, giving a weak/intermittent spark. (maybe the long drive the day before finally pushed one over the edge) Both will often operate fine when cold but then cause a problem after the tiny electricals inside get warm from operation. (sometimes in as little as a 5 mile drive) The condenser is easy and inexpensive to replace. The coil not so easy, needs to be sent to a rebuilder. I would be ready to check for a no spark condition on the next drive. When the stumbling happens, pull a spark plug wire (with a pliers or some other insulator) to see if you can see a spark. (your car should have a solenoid with a manual start button under it, so you can crank the engine from under the hood) If no spark, wait a half hour with hood open for the coil and condenser to cool. Then you may be able to drive home. Then again.....your particular problem may absolutely be something else, so you can ignore all that I wrote! This message was edited by JayChicago on 3-3-24 @ 11:16 AM
Drbrown | -- 03-04-2024 @ 7:11 AM |
Not to negate any concerns about possible ignition malfunction, with any car that sits for long periods of time during cold weather its important to keep the tank full so there's no to little air space which can contain moisture. Moisture can condense inside the distributor. Given today's gasolines, when coming back into use, drain the old gas out and refill. I use a gas life-extender additive which may help for short period s of non-use. Within reason, I use my "second-hand" gas in my mower and snow blower without problem.
JayChicago | -- 03-04-2024 @ 9:27 AM |
To my point that bad ignition can imitate bad fuel: Someone on the FordBarn asked, what are the symptoms of a coil going bad? This reply was posted by Kube, the club's 1940 advisor, been working on flatheads for decades: "Before the engine stops running, it will often act as if it is starving for fuel. Also, once it (engine) finally dies, it will usually start back up after an hour or so and run okay for a short time until the symptoms repeat themselves."
Robert/Texas | -- 03-04-2024 @ 3:00 PM |
Thanks for all of your thoughtful and helpful suggestions. I’m quite sure that I don’t have an ignition problem because I get a good spark when cranking the engine with one of the sparkplugs removed. Also, I had the distributor repaired by Charlie Schwendler and the coil rebuilt by Skip Haney a month or so before my health problems occurred. The condenser was replaced then too. I plan to remove the drain plug from the carburetor when I can get my great-grandson to come and help me. Then I’ll drain the fuel pump too, but I’m concerned about removing the plug from the 86-year-old gas tank, so I’ll try to siphon the gas out and refill it with a few gallons of fresh gas and a bottle of Heet. This will most likely take some time, but I’ll report back as soon as I can. Thanks again for your interest and help.
metalart | -- 03-04-2024 @ 6:55 PM |
Hi Robert, As I live in a different country I am not sure what HEET is, however when my father was alive he often used metholated spirits (about a quart per tank) to remove the water in the fuel tank. By draining the fuel bowl it was quick to check the quality of the fuel to begin with. Meth as we call it, seemed to help the engine run under normal circumstances. Good luck.
Robert/Texas | -- 03-10-2024 @ 1:26 PM |
I wrote that I would report back so here goes. My 16-year-old great-grandson volunteered to help me with my car. We started yesterday morning. The first thing we did was to double check the ignition system. Again, we got spark through the #7 plug, so we tried but failed to get the engine running with starter fluid. Next, we tried to remove the drain plug from the carb, but it wouldn’t budge so we removed the carb and fuel pump and drained them. Next, we removed the drainplug from the tank and drained around 8 0r 9 gallons of gas from it. The gas was nearly odorless and colored reddish yellow. We blew the old gas out of the fuel line and reinstalled the carb and fuel pump. We filled the tank with 5 gallons of 93 octane e-free gas with a red bottle of Heet added. The engine fired up quickly with the help of some starter fluid and we drove the car about 5 miles with no problems and went out to eat lunch at around 2:30. This message was edited by Robert/Texas on 3-10-24 @ 6:12 PM
1942deluxe | -- 03-10-2024 @ 5:51 PM |
Good job to both of you!
Drbrown | -- 03-12-2024 @ 10:24 AM |
To get rid of old gas and/or condensation/debris in the tank ..... Instead of draining your tank entirely thru the tank bottom drain plug, a hazardous process, at an Auto store buy a syphon-type assembly with extension hoses for excavating oil pans, gas tanks etc. I have one with about 1/2 inch sized extension hoses and used it when replacing my gas tank. One or two hand-pumps on the activator gets the syphon action going. In regard to gas tanks, syphon out as much gas as you can thru the fill pipe into 5 gallon containers. There will still be a small amount remaining in the bottom of the tank. Drain that thru the tank bottom plug. Then, to hopefully get every bit of water and debris out of the tank bottom, put a gallon or two of gas back thru the tank fill pipe and the tank's bottom drain. You can also drain the main gas line between the tank and fuel pump by opening the line's connection at the tank and fuel pump. As you said, drain your carb and fuel pump as best you can.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16934 |
