41fatty | -- 02-15-2024 @ 6:45 AM |
to replace harmonic balancer and pulley on 59AB:remove crank bolt clockwise? counter?
carcrazy | -- 02-15-2024 @ 11:50 AM |
To remove the center bolt on the crank pulley, turn it counterclockwise. If it is really tight, you may have to use an impact wrench to loosen it.
41fatty | -- 02-15-2024 @ 12:34 PM |
thank you for the quick reply
kubes40 | -- 02-15-2024 @ 5:13 PM |
Harmonic balancer? I do want to add that there is a cupped washer beneath the bolt. Be certain the convex side faces the bolt when reassembling. That is a Belleville washer and serves to "lock" that bolt in place similar to a split type lock washer. Mike "Kube" Kubarth
41fatty | -- 03-02-2024 @ 2:44 PM |
Thank you Mike, done and done. but now u got me wondering what I did. Time to double check the washer.
kubes40 | -- 03-04-2024 @ 9:50 AM |
Heck, I've double questioned myself so many times. Kinda hate it when that happens. Can't sleep until I go back.... Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16917 |
