wlzemke | -- 02-10-2024 @ 12:54 PM |
Hello members! I am working on a 35 ford 5 window that will have a 255 installed. I noticed that the intake manifold has fewer bolts mounting it than the 95 block has. I have two aftermarket aluminum manifolds and one has more holes than the other. Will they both fit on the 255?
carcrazy | -- 02-10-2024 @ 1:38 PM |
If your aftermarket aluminum intake manifolds are for 3rd generation Flathead V-8's, they will fit. The 3rd generation manifolds can be identified by their mounts for the road draft tubes used for the crankcase ventilation system.
wlzemke | -- 02-10-2024 @ 1:53 PM |
Will the extra bolt holes in the manifold just seal off on the intake deck?
carcrazy | -- 02-10-2024 @ 4:49 PM |
Yes.
wlzemke | -- 02-10-2024 @ 5:55 PM |
Thanks for your help!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16909 |
