chucky | -- 02-10-2024 @ 7:10 AM |
I put a signal switch in my 36. Worked fine for a while. Now blinkers come on but don't blink. Four ways work fine. Blinkers also seem a little dim. Appreciate any thoughts. Thanks...
trjford8 | -- 02-10-2024 @ 8:52 AM |
Check all your grounds. The clue is the fact they are dim. Depending on the switch you are using you may need to run a ground wire from the switch body to a good ground on the body.
chucky | -- 02-10-2024 @ 12:31 PM |
I will give that a try. Thanks...
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16908 |
