flathead48 | -- 01-12-2024 @ 3:12 AM |
I am replacing the rubber bushings in the panhard bar & rear spring. Is it advisable to use any lubricants on these or just put them in dry. Thanks, Rick
trjford8 | -- 01-12-2024 @ 7:55 AM |
You can use a grease called Sylglide on the rubber. Can be purchased at your local Napa store. It's a silicone based grease. Only takes a small amount.
kubes40 | -- 01-12-2024 @ 8:00 AM |
Rick, you can install them with your fingers, no lubrication is required. Mike "Kube" Kubarth
flathead48 | -- 01-12-2024 @ 9:04 AM |
Thanks guys for the tips. Happy New Year
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16869 |
