jamesmundstock | -- 12-29-2023 @ 12:43 PM |
My running boards are the aluminum type with no rubber. I was able to remove the stainless trim and the bottom vee shape that hooks on the lower edge of the aluminum running board had a black hard material that looks like it was applied before the trim was installed. The black material fell out and now the trim is loose. I am looking for suggestions what the black material is and what have other restorers have done when installing the running board trim. Thanks in advance for the replies.
flathead48 | -- 12-29-2023 @ 2:19 PM |
I have aluminum running boards, don’t believe there should be, perhaps the V in bottom of trim is spread to wide because of spacer used. I would try & tighten up the bottom V Happy New Year
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16842 |
