coup | -- 12-07-2023 @ 3:49 PM |
Is there a correct side that touches the hub? And how to know? Thanks for any info.
3w2 | -- 12-07-2023 @ 5:10 PM |
If you mean contacts the inside of the brake drum, that's the side with the recesses for the heads of the rivets as they normally came with the rivet attachment holes drilled and counter-bored for the rivet heads.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16802 |
