LarryK | -- 10-27-2023 @ 2:55 AM |
The horns on my 1939 Deluxe Tudor have stopped working. I have replaced the relay with a NOS 91A 13842. I soldered the wiring harness connections to the relay. I have full battery voltage between the wiring harness connections and ground. Next, I am considering checking the connections at the light switch. Any suggestions as to where else I should look? Thanks, LarryK Larry
marko39 | -- 10-27-2023 @ 5:20 AM |
try putting 6 volts directly to the horns from the battery, that will tell if the problem is with the horns or elsewere.
juergen | -- 10-27-2023 @ 5:20 AM |
Suggestion already made This message was edited by juergen on 10-27-23 @ 5:21 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16730 |
