dlpierson | -- 10-25-2023 @ 3:37 PM |
I’ve been told that the canister style bypassing oil filter on my ‘50 v8 is just for show and doesn’t do much and I need to convert to a full flow cartridge style for good filtering. True? How efficient is the bypass type? Doesn’t it clean all the oil but not in one pass from the oil pump?
ford38v8 | -- 10-25-2023 @ 4:10 PM |
You've been told wrong. The Ford bypass filter is an excellent system that needs no updating. Pull a search on the topic for your own education and don't listen to the fools flapping their lips. Alan
JayChicago | -- 10-26-2023 @ 8:56 AM |
I recall reading somewhere that someone took the time to measure how much oil actually moves thru the by-pass filtering system. Was something like a quart per minute at driving RPM. So, in just five minutes of driving the entire oil quantity runs thru the filter. Seems like that would be doing some good.
dlpierson | -- 10-26-2023 @ 12:16 PM |
Thanks
dlpierson | -- 10-26-2023 @ 12:17 PM |
Thanks. Sounds reasonable.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16725 |
