Sezgin | -- 09-18-2023 @ 7:10 PM |
I have been told that my motor Takes a 18mm diameter spark plug which appears to be correct. The problem I am having is the pitch measurement on plugs appears To be 1.5, but my head appears To Need a finer thread 1.25 pitch. Does anyone have any similar issues with what I am describing? Does anyone know where IMay be able to find a plug that would fit? Is there any other solution that I may be overlooking? Thanks for Any help.
carcrazy | -- 09-18-2023 @ 8:14 PM |
Which engine does your 1937 Flathead have? The 60 HP engine takes a 14 mm spark plug. Champion H10 was installed at the factory. The 95 HP 21 stud V-8 engine takes an 18 mm spark plug. Champion 7 two piece spark plugs were installed at the factory. Later replacement one piece Champion 7 spark plugs were used as service replacements.
carcrazy | -- 09-18-2023 @ 8:18 PM |
Regardless of the engine you have, you should be able to find spark plugs that will fit from Van Pelt.
same | -- 09-19-2023 @ 12:41 PM |
I have a '37 85 hp iron heads which i use autolite 386 18mm 1/2"reach plug. have got them from napa or oreillys.they have been working well. 3-4 $ each. Tom.
Sezgin | -- 09-20-2023 @ 4:23 PM |
Thanks for the responses, it turned out I had dunked Up threads in the Heads which I had mistaken for incorrect thread pitch. Chased the threads and plugs are now Installed. Thanks again
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16676 |
