chucky | -- 08-22-2023 @ 3:51 PM |
anyone have any information or opinions on the using brake floaters on a 36 ford. Thanks...
alanwoodieman | -- 08-22-2023 @ 6:08 PM |
I have installed floaters on several cars--model a pu with 60hp, 34 coupe, 37 sedan, 38 sedan and an almost original 36 4 door sedan all of these worked out great, I think that the flathead teds are the best--makes them stop better than hydraulics
rabidlayer | -- 10-02-2023 @ 2:13 AM |
There are two different wedges for 36. If your brake pedal has the number 17 embossed on the arm inside the car you need 68-2050 which is the later style. Early style is the same as 35 Ford 48-2050 the 68- style results in a smoother brake. This message was edited by efv8CofAAdmin on 10-17-23 @ 9:31 PM
ndnchf | -- 10-02-2023 @ 2:37 AM |
I have the older style floaters with star wheel adjusters on my "35 Fordor. They work great. The brakes feel and stop like modern hydraulic drum brakes.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16622 |
