thirtysixford | -- 07-16-2023 @ 11:18 AM |
Going to buy a new Stromberg carb.. I see they have the original type 97 around 162 cfm, and a Big97 around 250 cfm. The Big97 is actually a little less money and is in stock at Summit. Don't want to over carb. Stock 59AB Any thoughts? This message was edited by thirtysixford on 7-16-23 @ 1:08 PM
Drbrown | -- 08-04-2023 @ 7:57 AM |
Before you change I recommend asking the advice of Charlie Schwendler who has been rebuilding carbs for decades. (716) 662-9159 or cas5845@yahoo.com. He likely knows the differences in construction of the carbs you mention and what if any effect the change would have. Otherwise I can only add that there was another long-time carb rebuilder fellow in CT (whose name escapes me) who retired about 8 or 10 years ago, who was of the adamant opinion that one should stick with whatever stock carb type came on the engine.
carcrazy | -- 08-04-2023 @ 1:06 PM |
Ken Isidor from CT is another long-time carburetor rebuilder. The last contact info. that I have for him is igadore@sbcglobal.net (203) 260-9780. Going to a larger carburetor on a stock engine may not be a good idea. You want the airspeed through the venturi area to be sufficient to provide enough fuel at the lower engine speeds where you do most of your driving.
MG | -- 08-04-2023 @ 2:02 PM |
Sadly, Ken Isidor passed away December 29, 2022...
Drbrown | -- 08-05-2023 @ 7:44 AM |
Sorry to hear of Ken's death. I dealt with him a number of times and bought some of his close-out stock. He was a very knowledgeable asset to our cause.
juergen | -- 08-09-2023 @ 6:07 AM |
You have a stock 59AB. The original carb provides the proper air/fuel ratio. To use more air/fuel, you need to increase rpm. Your stock engine can't rev fast enough to make use of the extra flow. It would be like having a 4 barrel and only being able to use the primaries.
thirtysixford | -- 08-09-2023 @ 1:12 PM |
With some valuable guidance from Mad Max Musgrove, I bought the smaller 9510A-VP Stromberg the VP has a vacuum port for the distributor. Max is the Go To guy for the 97 he has new hand throttle linkage as well as other replacement parts. email info@97-express.com
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16554 |
