blarge | -- 07-07-2023 @ 10:45 AM |
I am replacing the clutch in my 48 Mercury. Since the transmission will be out, I want to repack the U joint with new grease. What is the best type to use and how much should I put in or should I use the grease zerk on the lower 1/2 moon shaped cover? Thanks, Bill Large
pauls39coupe | -- 07-07-2023 @ 3:31 PM |
Try using John Deere Corn Head grease, available at JD Farm stores like Hutsons. It is soft at room temperature so it won't channel like a stiff chassis grease. Just pump it in with a regular grease gun. Don't overdo it. It is also EP rated so it should work well in your U-joint. Corn Head grease also is a good lube for steering gear as it is thick enough to stay in the steering box even if the seals are starting to go bad.
carcrazy | -- 07-07-2023 @ 4:38 PM |
The Corn Head Grease will probably work alright. The reference book (owner's manual) for a 1941 Ford - I don't have one for a '48 Mercury says to use "UNIVERSAL JOINT LUBRICANT (Cylinder Oil Soda Soap Grease)" in this universal joint and to apply it via the grease fitting every 1000 miles!
1931 Flamingo | -- 07-08-2023 @ 5:41 AM |
A noted fella on the Ford Barn "A" Forum uses Mystyque grease (it's red)). FWIW Paul in CT
blarge | -- 07-09-2023 @ 11:18 AM |
Thanks for the info, I will buy some of the John Deer Corn Head grease. Bill Large
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16532 |
