dlpierson | -- 05-21-2023 @ 1:24 PM |
Is there a bench test for my 6 volt coil for my ‘50 Ford v8?
rustedorrotting | -- 05-21-2023 @ 1:58 PM |
connect 6 volts to negative side of coil and connect a lead to the high tension side of the coil ( a spark plug wire ) run another lead to positive side of the coil and momentarily ground it ( simulating points opening and closing ) high tension should produce a nice spark when you break the connection. Imho.
JayChicago | -- 05-21-2023 @ 6:13 PM |
Coils (and condensers) will often work fine when cold, but then fail when warm from usage. A bench test won't tell you how it will act under real life conditions.
Drbrown | -- 06-25-2023 @ 9:21 AM |
I assume you would do the test "rustedorotted" suggests on-the car. I believe you you should get a healthy spark up to 3/8 inches or so gap.
ndnchf | -- 06-25-2023 @ 2:17 PM |
An old school coil and condenser tester is what you need. My old 1940s era Herbrand tester is just the tool. It even has a Heat setting to re-heat the coil to simulate underhood conditions. I demonstrate it in this short video, and also show the effect of bad condenser on the spark. https://youtu.be/7thA6UA5kbk
mfirth | -- 06-26-2023 @ 4:30 AM |
ndnchf, was that Herbrand tester made in Fremont Ohio ? There was a "tool maker" company in Fremont that made all kinds of tools, but i'm not sure about electrical items. Thanks !!!! Mike
ndnchf | -- 06-27-2023 @ 2:51 AM |
Yes it was.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16429 |
