JohnA | -- 05-14-2023 @ 2:23 PM |
What would cause a whistle on my 239 59a and cause engine to blow black smoke and only run with choke on??, plus hard to start. Johna
pauls39coupe | -- 05-14-2023 @ 4:48 PM |
Sounds like a vacuum leak. Plug the line going to the wipers from the manifold base, and check the carb base gasket.
trjford8 | -- 05-15-2023 @ 7:31 AM |
X2 on the vacuum leak.
JohnA | -- 05-15-2023 @ 2:34 PM |
Thanks fellas
rustedorrotting | -- 05-22-2023 @ 8:58 AM |
Buy a mechanic's stethoscope and unscrew the tube that goes to the transducer from the ear pieces. So you have an ear piece in each ear the "y" and a short piece of hose. Works very well to locate leaks.
Barney | -- 05-22-2023 @ 4:24 PM |
John A I would bet dollars to doughnuts it's a fairly serious vacuum leak. With the engine idling, spray a small bit of ether in any suspect area. When the RPMs quickly increase, you found the leak. Barney
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16413 |
