jamesmundstock | -- 05-10-2023 @ 10:49 AM |
I purchased a special tool that depresses the spring collar on the trim ring and it has a center punch to drive the pin out. I read on the internet the pins are tapered. If this is true, how do you know which way to drive the pin out? When I push the spring ring back, I can’t see well enough to tell if one side is larger or not. Thanks in advance for the reply.
woodiewagon46 | -- 05-10-2023 @ 11:23 AM |
No the pin is not tapered, it will come out from ether side.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16397 |
