pattkarr77 | -- 03-17-2023 @ 6:36 AM |
I have a 1935 Coupe 350 chevy with a mustang 11 front end. I am looking for alignment specs. Any help would be appreciated.
carcrazy | -- 03-17-2023 @ 7:07 AM |
Why not just start with the wheel alignment specs. for a 1978 Mustang II.
gwistrup | -- 03-17-2023 @ 8:54 AM |
A basic setting of 3 degrees positive caster, around zero degrees camber and 1/16" toe in should get you started. More positive caster will give you more straight line stability making the vehicle a little harder to steer at slow speeds if you don't have power steering.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16301 |
