Civilwarlife | -- 03-07-2023 @ 3:55 PM |
I need a Ford script battery for my 1938 Ford tudor. I'm going to the 60th anniversary show in Dearborn in June. I have a battery on order but it doesn't look like it will be here in time. If you have a battery you can sell me or even loan me at the show, please let me know. I will be grateful Terry They are only original once
Jacques1960 | -- 03-08-2023 @ 4:59 AM |
And if anyone has a truly good method for painting the gold oval, please post it. I’ve tried Testors via both foam roller and brush and was not satisfied with either. Thank you.
ford38v8 | -- 03-08-2023 @ 5:17 AM |
Foam roller is too soft. You have a smooth hard surface with sharp detail cuts, meaning you need a fairly hard rubber printing roller. There are small printing rollers at hobby shops. Testers gold works well with those rollers, just a little dab will do ya, roll it out back and forth on a flat surface for a correct amount of paint, then go for it. Remember, this was done at the factory, just takes a few seconds, and on to the next battery. Alan
JayChicago | -- 03-08-2023 @ 6:43 AM |
"Remember, this was done at the factory, just takes a few seconds, and on to the next battery." Agree. If you get this too perfect you probably have "over-restored". The factory would not have had motivation to make it perfect. I doubt that customers would have complained about imperfect lettering on their battery.
Jacques1960 | -- 03-11-2023 @ 5:42 PM |
Thank you
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16279 |
