chrisbob12 | -- 10-18-2009 @ 8:41 PM |
I'm looking for specification to build a rear shelf assembly for my 1947 business coupe. I have nothing there. Thank you, Bob,
Steves46 | -- 10-19-2009 @ 11:44 AM |
If you haven't already, you may want to check with LaBarron-Bonney or Macs (Cartouche) probably mispelled it. Good luck.
trjford8 | -- 10-20-2009 @ 8:22 AM |
Steve46 makes a good suggestion.Contact LeBaron-Bonney or Cartouche and and see if they have a paper pattern of the package shelf. If not, just order the carboard cover from them and use it as a pattern.The package shelf is generally 5/8 plywood. Not sure about your car, but most of the cars with a package shelf have a wooden brace at the middle of the front edge that goes down to the center of the drivehshaft tunnel. You should find a metal tab welded to the tunnel to attach to the brace.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=162 |
