usered | -- 01-17-2023 @ 10:40 AM |
I know there's been a lot of discussion on this topic, but I have a couple of questions. I'm adding a partial remote oil filter to my 59ab engine. I want to run a line from the orifice on the back of the block to a remote oil filter and the outlet line down to my dip stick mount which already has a 3/8 npt hole drilled in it. Will this work ok? Will I need an oil restrictor going into the oil filter? This is mild 59ab used for just causal driving.
kubes40 | -- 01-17-2023 @ 10:42 AM |
The routing you are planning is proper. You MUST have a restrictor, or you WILL lose oil pressure. The factory specification was .060" - .063". If you can't find a restrictor fitting, it's easy enough to solder your existing fitting and drill to the proper diameter. Mike "Kube" Kubarth
usered | -- 01-18-2023 @ 6:27 AM |
Thanks for the response. Not finding a restrictor 060" - 063", there are 065" restrictors apparently for mustangs. would 065" be too big? Plan on running an AN line, what size would be apporiate 2AN or a 3AN?
kubes40 | -- 01-18-2023 @ 6:29 AM |
I'd think .065" would be fine. I'm not certain how AN line is measured. Originally, the lines were 1/4" diameter. Mike "Kube" Kubarth This message was edited by kubes40 on 1-18-23 @ 6:30 AM
usered | -- 01-18-2023 @ 7:28 AM |
Thanks again for the response. FYI AN 4 is 1/4" OD, so that probably AN 5 or 6 would work fine.
51504bat | -- 01-18-2023 @ 8:43 AM |
Napa # wh1512 ______________ No signature
Jerry_Woods | -- 01-21-2023 @ 7:27 AM |
It should work to run a line from the orifice on the back of the block to a remote oil filter and the outlet line down to your dipstick mount if the correct fittings and hose are used. An oil restrictor may not be necessary, but it depends on the specific design of the remote oil filter you are using. It's best to consult the instructions or technical support from the manufacturer of the remote oil filter to determine if an oil restrictor is needed or not. https://aftermarketparts.org/ford/f-150/2019/ This message was edited by Jerry_Woods on 2-14-23 @ 11:43 AM
ford38v8 | -- 01-21-2023 @ 12:51 PM |
It has not been established, but assuming that the desired filter setup is a bypass system as original, it would need the restrictor on the inlet side of the filter. Alan
kubes40 | -- 01-21-2023 @ 1:07 PM |
Alan is 100% correct. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16192 |
