fordcpe | -- 01-14-2023 @ 2:31 PM |
I purchased a new starter for my 47 Ford but have a concern. It came with a note that said this starter is bigger than the original because of the new improved bendix. It says I have to grind a bit of the metal off the starter plate to allow the starter bendix to fit past the flywheel gear. How do I remove that starter plate to do this?
51504bat | -- 01-14-2023 @ 2:51 PM |
Or you can use an original style Bendix and not have to grind anything. ______________ No signature
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16186 |
