Topic: brake cross shaft
flatfoot    -- 11-29-2022 @ 5:42 PM
  Are there bearings for the brake cross shaft assy? This is what moves when I apply the brakes and maybe the reason I cannot get a better pedal on my '36 Ford Fordor Sedan?
This message was edited by flatfoot on 12-21-22 @ 1:24 PM
kubes40    -- 11-30-2022 @ 5:48 AM
  Are the shoes adjusted properly at each and every drum? Are the links, both the clevises and pins truly round and not worn out? A small amount of wear at each clevis / pin adds exponentially to a lot of pedal travel.
The cross-shaft assembly can be worn out as well.
trjford8    -- 11-30-2022 @ 6:16 AM
  It's been a long time since I worked on mechanical brakes, but as I recall I believe the cross shaft has bushings and not bearings.
1931 Flamingo    -- 11-30-2022 @ 10:52 AM
  Is there play/looseness in the shaft??
Paul in CT
flatfoot    -- 11-30-2022 @ 11:28 AM
  There is play/looseness in the shaft.
1937sedandelivery    -- 11-30-2022 @ 1:25 PM
  My 37 shaft has bushings, which I replaced. Not sure, but I think I got them from Joe's Antiques.
gregg
flatfoot    -- 12-19-2022 @ 9:05 AM
  Thanks to all for your input re the mechanical brakes issues. I have used all of your suggestions and have good pedal and brakes are great. The shaft does have bushings and I replaced them and readjusted the brakes. Wow, I got pedal now.
Thank you to all and wish all a Merry Christmas and a prosperous New Year. God bless all.
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=16105
